Contopus Phone Connection Monitor
Chatopus
Contopus monitors your phone connection with your Pebble in the background. When your phone goes out of range, you will get an alert. You can then snooze or dismiss your alarm. It works with all watch faces and regardless of any screen you are in your Pebble. You will never forget to bring your phone or miss any notification due to a bluetooth disconnection. Others features: Configurable to disable alert during Quiet Time or sleep. Support Pebble Time 2 speaker for an audible alert.
- DeveloperChatopus
- CategoryTools & Utilities
- PlatformsOG Pebble, Steel, Time/Time Steel, Time Round, 2, 2 Duo, Time 2, Round 2
- Updated2026-10-23
- Version1.10
