HomeP - For MyQ Garage Doors & Light Switches
SeaPea Software
Unofficial watch app for monitoring and operating Chamberlain/Liftmaster branded MyQ devices over the Internet (Requires MyQ Internet Gateway, usually sold separately) , now including the "MyQ Garage" device, which connects to 3rd party garage doors.
Currently supports garage door openers AND light switches - other types of devices may be added soon.
- Uses SSL to communicate securely with the official MyQ servers
- Does NOT require a companion app on your phone
- DOES require your Pebble to be connected to your phone and your phone to have a data connection (bear in mind that you may be on the edge of your home wifi just outside your garage)
- Username and password is stored on your phone and are only ever sent to the official MyQ servers. Password is also encrypted on your phone
- Up/Down switches devices
- Select changes the status of the device
- To save Pebble battery it does not constantly monitor the device status except when opening/closing a garage door. To update the status, switch devices with the Up/Down button (even if you only have one device) or reopen the app
- Closes automatically after 2 minutes of inactivity to help avoid accidentally operating a device
- Assign it to a Quick Launch button in your Pebble settings for easy access
  • DeveloperSeaPea Software · Is this you? Claim your app ›
  • Updated2015-11-07
  • Version2.2
