System Info
rigel314
Hexeditor and Disassembler for your watch.
This is a DANGEROUS tool, not a toy. Be careful with it. Misuse could brick your Pebble.
Some areas of memory are not allowed to be read. If you try, the app will crash. Trying to read protected memory should not harm your Pebble, but still be careful.
On the edit screen, up and down modify the selected nibble and select moves to the next.  Long press select to save.
On the dissassembly view, pressing Down will scroll by the instruction size at the top of the screen, where as pressing Up will always scroll up by the minimum instruction size(2). Pressing Select will toggle showing instruction bytes.
  • Developerrigel314 · Is this you? Claim your app ›
  • Updated2015-08-16
  • Version2.2
