DBZ Power Level Tracker
Julien1138
# DBZ Power Level Tracker
A Dragon Ball Z-themed Pebble watchface that tracks your daily step count as a power level. Reach the configured step threshold and watch your character transform into a Super Saiyan.
## Features
- Step count displayed as a power level in bright green (black on B&W devices)
- Choose between **Goku** and **Vegeta** as your character
- Character transforms to Super Saiyan at the configured step threshold, with a multi-phase animation and vibration sequence
- Goku plays a stretching animation on wrist shake; Vegeta throws punches
- Configurable Super Saiyan step threshold (default: 7,000 steps)
- Transformation vibration configurable; automatically suppressed when charging or in silent mode
- Clock display with system time format (12h / 24h)
- Date display
- Battery level indicator with color-coded bar (green / yellow / red)
- Vibration alert when Bluetooth disconnects (configurable)
- Bardock expressions react to character state and animations
- Shake wrist to stop vibrations during a transformation
## Configuration
Open the Pebble app and tap the settings icon on the watchface to configure:
- **Character** — Goku or Vegeta
- **Super Saiyan threshold** — daily steps required to trigger the transformation
- **Vibrate on transformation** — toggle transformation vibration (always off when charging or in silent mode)
- **Vibrate on disconnect** — toggle vibration when Bluetooth disconnects
## Inspiration
- Watchface concept: [Poke Trainer](https://apps.repebble.com/poke-trainer_579c8add1482cd051500038f) by the Rebble community
## Credits
- Sprites and background images: [Sprite Database -- Dragon Ball Z](https://spritedatabase.net/game/383)
- Bardock expressions: [Spriters Resource -- Dragon Ball Customs](https://www.spriters-resource.com/custom_edited/dragonballcustoms/asset/16602/)
## Contributing
Contributions are welcome via pull requests.
  • DeveloperJulien1138
  • Updated2026-05-08
  • Version1.4.1
