Nothing Battery
Tom Khamis
Pebble Battery is a clean, glanceable battery app inspired by the Nothing Phone widget aesthetic. The main screen fills the display with a bold dot grid, purple on dark, red on light, where each circle represents a portion of your remaining charge. The current percentage is displayed prominently at the top using a dot-matrix LED-style font. Press UP or DOWN to open the summary view, which shows your estimated time remaining (or time until full when charging), drain rate in %/HR, and the last recorded delta. Press SELECT to toggle between dark mode (black background, purple dots) and light mode (white background, red dots, gray empty circles), your preference is remembered between sessions. When the battery drops below 20%, the percentage and dots turn red as a low-battery warning. When charging, an animated wave of dots sweeps across the grid.
- DeveloperTom Khamis
- CategoryTools & Utilities
- PlatformsOG Pebble, Steel, Time/Time Steel, 2, 2 Duo, Time 2
- Updated2026-08-06
- Version1.0.5
