Phone Sound Mode
Ark-am
Phone Sound Mode puts your phone's ringer at most 2-clicks-out*. Switch your phone to Normal, Silent, or Vibrate straight from your Pebble watch. Open the app, choose a mode, and you're done; the list can be reordered from the Pebble app. A short vibration confirms that your phone has changed, and the app returns to your watch-face after the confirmation. If the change can't be made, the app stays open and tells you why, so you can try again. Clear icons for each mode make it easy to pick the right one at a glance. On colour watches each mode has its own colour (green for Normal, blue for Silent, grey for Vibrate), and the status bar turns that colour when your phone confirms the change, or red if something goes wrong. Android only. Phone Sound Mode requires its free Android companion app, located on our website: https://ark-am.com/projects/pebble-apps Or Download the app directly from: https://ark-am.s3.us-east-1.amazonaws.com/App_Pebble/phone-sound-mode-version-1.apk Once installed, open the companion app and allow Do Not Disturb access, which Android needs to reliably switch into and out of Silent mode. Nothing is sent to a server; the watch talks only to your phone. Created by Ark-am LLC. Discover our work and custom software development services: https://ark-am.com/ *Shout out to the YouTube channel, "Dave Moss Tuning".
- DeveloperArk-am
- CategoryTools & Utilities
- PlatformsOG Pebble, Steel, Time/Time Steel, Time Round, 2, 2 Duo, Time 2, Round 2
- Updated2026-10-29
- Version1.0.8
